TPA3245EVM: TPA3245EVM 2 x BTL x 2pcs
Part Number: TPA3245EVM
Other Parts Discussed in Thread: TPA3245
I am considering an audio amplifier of BTL x 4 ch using two TPA3245EVM.
In order to synchronize these two amplifiers, make fpwm common.
At this time, OSC_IOP of MASTER board and OSC_IOM of SLAVE board are connected.
Then, the output was intermittent like the attached waveform.(LED of CLIP_OTW is lights up.)
Do you know the cause of this event?
When OSC_IOP and OSC_IOM were not connected and both were MASTER, it worked without any problem.
How do I select SLAVE 1 and SLAVE 2?
EVM SETTING
J21:open
J5:short
J6:short
J16:No1.Master mode,No.2 Slave mode
J3:SE input
J4:SE
J26:short(INA=INC)
J27:short(INB=IND)
J7:open
J8:open
No.1.tif
No.2.tif
    I think I see what may be the issue here.  OSC_IOP and OSC_IOM have to be connected on both boards. You can either use with the same polarity for slave mode 1 (OSC_IOP master to OSC_IOP slave and OSC_IOM master to OSC_IOM slave) or with inverse polarity for slave mode 2 (OSC_IOP master to OSC_IOM slave and OSC_IOM master to OSC_IOP slave) .  This information can be found in the second paragraph of 1.2 TPA3245EVM Frequency Adjust in the EVM user guide or in 10.2.1.2.4 Oscillator in the TPA3245 datasheet.
    I tried attaching just OSC_IOP master to OSC_IOM slave on some EVMs in the lab and leaving the rest unattached and I got similar results to what you found.
    Dan
  • Hi,thank you for your reply.
    I connected OSC_IOP MASTER (10pin) and OSC_IOP SLAVE (10pin), and connected OSC_IOM MASETR (9pin) and OSC_IOM SLAVE (9pin).
    EVM -BOARD worked normally in this state, so, is there a problem?
    ・Question
    1. Is OSC-IOP "+" polarity ? Is OSC_IOM "-" polarity?
    2. Which pin does OSC_ION show?
    Best regards.
    Glad to hear the EVM is working now. No there is no problem, this is expected behavior. OSC_I/O pins as inputs need to be slaved from an external differential clock.
    1. Yes, OSC_IOP for "+" and OSC_IOM for "-".
    2. That was my mistake. OSC_ION is not the name for that pin. I was thinking OSC_IOP for positive and OSC_ION for negative. You are correct: it is OSC_IOP for "plus" and OSC_IOM for "minus". I have edited my above response so hopefully it does not confuse others.
    Dan
  • Hi, Dan
    Thank you for your nice support! I understood.
    Please let me question if there is any doubt.
    Okaz
