What should be CM setting in Audio codec TLV320AIC3120 if i am using MIC_LP pin for mic connection?What roll will feed forward resistance will play if i select 10K,20K or 40K?
thanks Luis for reply
What will happen if i will not connect unused(floating) mic input to CM internally. This is option available in TLV320AIC3120 by programming codec internal resistor.
Also there is option not to connect CM to MIC PGA . Is there ant application note for highlighting concept of CM?
regards
AMIT
