AIC3204 Attenuation over 24 Khz
Other Parts Discussed in Thread: TLV320AIC3204
i configure AIC3204 like this:
	 ; Point to page 0
        AC1 = #0
        AR1 = #0x0
        call i2c_WriteData8
        ;reset codec
        AC1 = #1
        AR1 = #0x1
        call i2c_WriteData8
	 ; Point to page 1
        AC1 = #0
        AR1 = #0x1
        call i2c_WriteData8
        ;Disable crude AVDD generation from DVDD
        AC1 = #1
        AR1 = #0x08
        call i2c_WriteData8
        ;Enable Analog Blocks and LDO
        AC1 = #2
        AR1 = #0x01
        call i2c_WriteData8
        ;* PLL and Clocks config and Power Up
    ; Point to page 0
        AC1 = #0
        AR1 = #0x0
        call i2c_WriteData8
        ;AIC is master running off of 1.288 MHz crystal
        ;BCLK and WCLK is set as op to AIC3204(Master) - 16 bits word
        AC1 = #27
        AR1 = #0x0D
        call i2c_WriteData8
        ;PLL setting: PLLCLK <- MCLK and CODEC_CLKIN <-PLL CLK
        AC1 = #4
        AR1 = #0x03
        call i2c_WriteData8
        ;PLL Power up; PLL Divider params: P = 1, R = 1
        AC1 = #5
        AR1 = #0x91
        call i2c_WriteData8
        ;PLL setting: J=8
        AC1 = #6
        AR1 = #0x08
        call i2c_WriteData8
        ;PLL setting: HI_BYTE(D) for D=0x0780 (or 1920 decimal)
        AC1 = #7
        ;AR1 = #0x07
        AR1 = #0x00
        call i2c_WriteData8
        ;PLL setting: LO_BYTE(D) for D=0x0780
        AC1 = #8
        ;AR1 = #0x80
        AR1 = #0x00
        call i2c_WriteData8
        ;NDAC = 2
        AC1 = #11
        AR1 = #0x82
        call i2c_WriteData8
        ;MDAC = 8
        AC1 = #12
        AR1 = #0x88
        call i2c_WriteData8
        ;DOSR H  (DOSR = 32)
        AC1 = #13
        AR1 = #0x00
        call i2c_WriteData8
        ;DOSR L  (DOSR = 32)
        AC1 = #14
        AR1 = #0x20
        call i2c_WriteData8
        ;Clock Setting Register 11, BCLK N Divider N = 7
        AC1 = #30
        AR1 = #0x87
        call i2c_WriteData8
        ;Power up NADC and set NADC value to 2
	    AC1 = #18
	    AR1 = #0x82
	    call i2c_WriteData8
	    ;Power up MADC and set MADC value to 8
	    AC1 = #19
	    AR1 = #0x88
	    call i2c_WriteData8
	    ;AOSR for AOSR = 32
	    AC1 = #20
	    AR1 = #0x20
	    call i2c_WriteData8
    	; Point to page 0
        AC1 = #0
        AR1 = #0x0
        call i2c_WriteData8
		; DAC PRB
		AC1 = #60
        AR1 = #21
        call i2c_WriteData8
        ; ADC PRB
		AC1 = #61
        AR1 = #0x0E
        call i2c_WriteData8
     ;* DAC ROUTING and Power Up
        ;Select page 1
        AC1 = #0
        AR1 = #0x01
        call i2c_WriteData8
        ;LDAC AFIR routed to HPL
        AC1 = #12
        AR1 = #0x08
        call i2c_WriteData8
        ;RDAC AFIR routed to HPR
        AC1 = #13
        ;AR1 = 0x08
        AR1 = #0x00
        call i2c_WriteData8
        ;Select page 0
        AC1 = #0
        AR1 = #0x00
        call i2c_WriteData8
        ;Left vol=right vol
        AC1 = #64
        AR1 = #0x02
        call i2c_WriteData8
        ;Left DAC gain to 0dB VOL; Right tracks Left
        AC1 = #65
        ;AR1 = #0x00  ; without DRC
        AR1 = 0x18    ; with DRC
        call i2c_WriteData8
        ; DRC
        ;DAC => DRC Enabled for left channels, Threshold = -24 db, Hysteresis = 3 dB
        AC1 = #0x44
        AR1 = #0x5F
        call i2c_WriteData8
        ;DRC Hold = 0 ms, Rate of Changes of Gain = 0.5 dB/Fs'
        AC1 = #0x45
        AR1 = #0x00
        call i2c_WriteData8
        ;Attack Rate = 1.9531e-4 dB/Frame , DRC Decay Rate =2.4414e-5 dB/Frame
        AC1 = #0x46
        AR1 = #0xB6
        call i2c_WriteData8
        ; END DRC
        ;Power up left,right data paths and set channel
        AC1 = #63
        ;AR1 = #0x92
        AR1 = #0xB2
        call i2c_WriteData8
        ;Select page 1
        AC1 = #0
        AR1 = #0x01
        call i2c_WriteData8
        ;Unmute HPL , 0dB gain
        AC1 = #16
        AR1 = #0x00
        call i2c_WriteData8
        ;Mute HPR , 0dB gain
        AC1 = #17
        AR1 = #0x00 ;#0x40
        call i2c_WriteData8
        ;Power up HPL
        AC1 = #9
        ;AR1 = 0x28 -- prec
        AR1 = #0x30
        call i2c_WriteData8
		;Select page 0
        AC1 = #0
        AR1 = #0x00
        call i2c_WriteData8
		@BRC0_L = #0x02FF || mmap()
		localrepeat {
			repeat(#0xFFFF)
			NOP_16
			NOP_16
        ;* ADC ROUTING and Power Up
		;Select page 1
	    AC1 = #0
	    AR1 = #0x01
	    call i2c_WriteData8
		AC1 = #52
	    AR1 = #0x30
	    call i2c_WriteData8
		;CM_1 (common mode) to LADC_M through 40 kohm
	    AC1 = #54
	    AR1 = #0x03
	    call i2c_WriteData8
		;MIC_PGA_L unmute
	    AC1 = #0x3B
	    AR1 = #0x5D
	    call i2c_WriteData8
		;MIC_PGA_R unmute
	    AC1 = #0x3C
	    AR1 = #0x80
	    call i2c_WriteData8
        ;Select page 0
        AC1 = #0
        AR1 = #0x00
        call i2c_WriteData8
        ;Powerup Left ADC
        AC1 = #81
        AR1 = #0x80
        ;AR1 = #0x8A
        call i2c_WriteData8
        ;Unmute Left ADC and mute Right ADC
        AC1 = #82
        ;AR1 = 0x00 -- prec
        AR1 = #0x08
        call i2c_WriteData8
I put  a sinusoid as input signal with a function generator and i see the output with a scope.
My problem is that over 24-25 Khz my signal is attenuated, and existguishes at 40 Khz.
How can i pass the signal up to 50 Khz?
Thanks in Advance
Paolo
