Part Number: SRC4190
Hi Sirs,
Sorry to bother you.
As title, we would like search solution do ADSC between ADI ADV7619 and FPGA
Does SRC4190 is suitable solution?
If not, have others solution can do it?
Thanks!!
Hi Sirs,
Thanks!!
Hi, Shu-Cheng,
Could you please provide more information about this request?, like the format used by each device and intended operation. The SRC4190 is an asynchronous audio sample rate converter that is intended to be used with audio data formats like I²S, TDM, LJ and RJ.
-Diego Meléndez López
Audio Applications Engineer
Hi, Shu-Cheng,
Thanks for the additional information. I guess the FPGA will always expect a 48KHz sample rate, while the ADV will provide either 44.1KHz or 48KHz, is this correct?. As mentioned before, the SRC4120 is a sample rate converter that can be configured as a bridge between audio interfaces with a different sample rate (as in this case), so I think this device could be recommended.
