TPA3140D2: Validity of efficiency
Guru 16770 points
Part Number: TPA3140D2
Hi
We want to verify the validity of efficiency that we obtained.
How to estimate the dissipation of TPA3140D2 itself?
BestRegards
    Shawn can help you out with estimating the efficiency of the device. He should be posting shortly.
    Alex
  • Hi na na,
    In efficiency measurement, you need to measure Pt(the total power consumption), Po(the output power on the load) and Pe(power loss on cables/inductors...). Then calculate the efficiency by (Po+Pe)/Pt. And the power consumption on the devie itself should be Pt-Po-Pe.
    Please note that this is a very sensitive mesasurement. The load resistance for each channel need to be measured by multimeter in Four-Wire(Kelvin) mode. And the cable resistance and inductor DCR can't be ingored.
    Shawn Zheng
