Part Number: PCM2912A
Hi Sirs,
Sorry to bother you.
We have use PCM2912A.
Issue as below
TA is 70 ºC, there is annoying noise, USB audio codec temp. = 88ºC
TA is 65 ºC, NO annoying noise, USB audio codec temp. = 82ºC
Is it normal? have any possible to fix this noise?
By the way, we found Pin24 pull high& pull low will have different Power consumption.
So if we setting from high to low (500mA to 100mA), the temp is possible to drop?
Have any risk on this change?
Thanks!!
