Other Parts Discussed in Thread: TAS6424, TAS6424L-Q1
Dear TI Community,
Dear TI Community,
Hi Darius,
Thank you for your interest in TI Class-D audio amplifier. Due to the popularity of TAS6424 the EVMs are on back order. I believe TAS6422 EVMs are available. It is similar to TAS6424 device in the software commands so it can be transferred easily to TAS6424 board.
The TAS6424 EVM User's Guide is also available online so please take a look. Please let me know if you have any questions once you peruse through the document.
Tuan
Thanks a lot. I found a European distributor with the 6422q1EVM in stock an if I understood you right, I can transfer everything I need to know to the 6424 board. So that Problem would be fixed.
I also found the userguide, which is also very helpful but does not contain the 4/8 Channel Reference Design the engineer is referring to in this video at 01:29
Is there a way to see this designs?
Best
Darius
