PurePath Generation Problem with new release
Hi everybody,
I downloaded the last version of PurePath Studio for AIC3254, but when I try to generate my processflow created with an older version, I've got the following errors :
Generating code for main_Rate44 ..  assembling ...MemoryType usage: miniDSP_A_coeff: 163, miniDSP_A_data: 282, miniDSP_A_instr: 731, miniDSP_A_instr_alloc: 744, miniDSP_A_cycles: 531, miniDSP_A_cycles_alloc: 1016,miniDSP_D_coeff: 189, miniDSP_D_data: 242, miniDSP_D_instr: 954, miniDSP_D_instr_alloc: 966, miniDSP_D_cycles: 768, miniDSP_D_cycles_alloc: 1016
Error: aic_gen.asm(61): Incorrectly formed directive For directive .coeff_adc            Dec4xIn_1_AGCn0and1          = 0,00560283660888671875M1        @0, expected decimal, hex, or Qfixed number, found: 0,00560283660888671875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(62): Incorrectly formed directive For directive .coeff_adc            Dec4xIn_1_AGCd1              = 0,9887943267822265625M1 @1, expected decimal, hex, or Qfixed number, found: 0,9887943267822265625M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(63): Incorrectly formed directive For directive .coeff_adc            Dec4xIn_1_n0                 = 0,99999988079071044921875M1   @2, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(1174): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_14_1_N0    =0,99788606166839599609375M1 @22, expected decimal, hex, or Qfixed number, found: 0,99788606166839599609375M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(1175): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_14_1_N1    =-0,99788606166839599609375M1 @22+1, expected decimal, hex, or Qfixed number, found: -0,99788606166839599609375M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(1176): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_14_1_N2    =0,99788606166839599609375M1 @22+2, expected decimal, hex, or Qfixed number, found: 0,99788606166839599609375M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(1177): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_14_1_D1    =0,99788379669189453125M1 @22+3, expected decimal, hex, or Qfixed number, found: 0,99788379669189453125M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(1178): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_14_1_D2    =-0,99577677249908447265625M1 @22+4, expected decimal, hex, or Qfixed number, found: -0,99577677249908447265625M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(1664): Incorrectly formed directive For directive .coeff_miniDSP_A     AGC_1_B0                =0,99999988079071044921875M1            @6, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(1669): Incorrectly formed directive For directive .coeff_miniDSP_A     AGC_1_ENERGY_COEF       =0,001887798309326171875M1        @11, expected decimal, hex, or Qfixed number, found: 0,001887798309326171875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(1670): Incorrectly formed directive For directive .coeff_miniDSP_A     AGC_1_ATTACK_COEF       =0,00565278530120849609375M1   @12, expected decimal, hex, or Qfixed number, found: 0,00565278530120849609375M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(1671): Incorrectly formed directive For directive .coeff_miniDSP_A     AGC_1_DECAY_COEF        =0,00151050090789794921875M1    @13, expected decimal, hex, or Qfixed number, found: 0,00151050090789794921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(1672): Incorrectly formed directive For directive .coeff_miniDSP_A     AGC_1_DESIRED_LEVEL     =0,2999999523162841796875M1 @14, expected decimal, hex, or Qfixed number, found: 0,2999999523162841796875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(1673): Incorrectly formed directive For directive .coeff_miniDSP_A     AGC_1_MIN_AUDIO         =0,000998973846435546875M1     @15, expected decimal, hex, or Qfixed number, found: 0,000998973846435546875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(1674): Incorrectly formed directive For directive .coeff_miniDSP_A     AGC_1_NOISE_LEVEL       =0,0000998973846435546875M2   @16, expected decimal, hex, or Qfixed number, found: 0,0000998973846435546875M2.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(1675): Incorrectly formed directive For directive .coeff_miniDSP_A     AGC_1_MIN_CHANGE        =0,006249904632568359375M1    @17, expected decimal, hex, or Qfixed number, found: 0,006249904632568359375M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(1676): Incorrectly formed directive For directive .coeff_miniDSP_A     AGC_1_MIN_GAIN_5        =0,09999847412109375M5      @18, expected decimal, hex, or Qfixed number, found: 0,09999847412109375M5.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(1678): Incorrectly formed directive For directive .coeff_miniDSP_A     AGC_1_INC_FACTOR_2      =1,0000782012939453125M2    @20, expected decimal, hex, or Qfixed number, found: 1,0000782012939453125M2.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(1679): Incorrectly formed directive For directive .coeff_miniDSP_A     AGC_1_DEC_FACTOR_2      =0,99979114532470703125M2    @21, expected decimal, hex, or Qfixed number, found: 0,99979114532470703125M2.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(3045): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_32_1_N0    =0,99999988079071044921875M1 @27, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(3054): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_32_2_N0    =0,99999988079071044921875M1 @32, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(3063): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_32_3_N0    =0,99999988079071044921875M1 @37, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(3072): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_32_4_N0    =0,99999988079071044921875M1 @42, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(3081): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_32_5_N0    =0,99999988079071044921875M1 @47, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(3090): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_32_6_N0    =0,99999988079071044921875M1 @52, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(3099): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_32_7_N0    =0,99999988079071044921875M1 @57, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(3108): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_32_8_N0    =0,99999988079071044921875M1 @62, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(3377): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_33_1_N0    =0,99999988079071044921875M1 @27, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(3386): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_33_2_N0    =0,99999988079071044921875M1 @32, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(3395): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_33_3_N0    =0,99999988079071044921875M1 @37, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(3404): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_33_4_N0    =0,99999988079071044921875M1 @42, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(3413): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_33_5_N0    =0,99999988079071044921875M1 @47, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(3422): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_33_6_N0    =0,99999988079071044921875M1 @52, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(3431): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_33_7_N0    =0,99999988079071044921875M1 @57, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(3440): Incorrectly formed directive For directive .coeff_miniDSP_A   Biquad_33_8_N0    =0,99999988079071044921875M1 @62, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(5220): Incorrectly formed directive For directive .coeff_miniDSP_D  WOW_HD_1_tb_TruBassCtrl      =0,299999713897705078125M1   @11, expected decimal, hex, or Qfixed number, found: 0,299999713897705078125M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(5221): Incorrectly formed directive For directive .coeff_miniDSP_D  WOW_HD_1_tb_IntegrationLmt   =5,49994659423828125M6 @11+1, expected decimal, hex, or Qfixed number, found: 5,49994659423828125M6.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(5223): Incorrectly formed directive For directive .coeff_miniDSP_D  WOW_HD_1_SpaceControl    =0,799999237060546875M1      @11+2, expected decimal, hex, or Qfixed number, found: 0,799999237060546875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(5224): Incorrectly formed directive For directive .coeff_miniDSP_D  WOW_HD_1_CenterControl   =0,3999996185302734375M1     @11+3, expected decimal, hex, or Qfixed number, found: 0,3999996185302734375M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(5225): Incorrectly formed directive For directive .coeff_miniDSP_D  WOW_HD_1_NormalizeGain   =0,52799999713897705078125M1     @11+4, expected decimal, hex, or Qfixed number, found: 0,52799999713897705078125M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(5228): Incorrectly formed directive For directive .coeff_miniDSP_D  WOW_HD_1_DfntnControl    =0,3999996185302734375M1 @11+6, expected decimal, hex, or Qfixed number, found: 0,3999996185302734375M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(5230): Incorrectly formed directive For directive .coeff_miniDSP_D  WOW_HD_1_FocusControl    =0,3999996185302734375M1      @11+7, expected decimal, hex, or Qfixed number, found: 0,3999996185302734375M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(7088): Incorrectly formed directive For directive .coeff_miniDSP_D  DRC_1_DRC_1_DRCAE     =0,0000226497650146484375Q23   @91, expected decimal, hex, or Qfixed number, found: 0,0000226497650146484375Q23.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(7089): Incorrectly formed directive For directive .coeff_miniDSP_D  DRC_1_DRC_1_DRC1AE    =0,9999773502349853515625Q23 @91+1, expected decimal, hex, or Qfixed number, found: 0,9999773502349853515625Q23.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(7092): Incorrectly formed directive For directive .coeff_miniDSP_D  DRC_1_DRC_1_DRCK2     =-0,65656566619873046875Q21   @91+4, expected decimal, hex, or Qfixed number, found: -0,65656566619873046875Q21.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(7097): Incorrectly formed directive For directive .coeff_miniDSP_D  DRC_1_DRC_1_DRCAA     =0,00009059906005859375Q23   @91+9, expected decimal, hex, or Qfixed number, found: 0,00009059906005859375Q23.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(7098): Incorrectly formed directive For directive .coeff_miniDSP_D  DRC_1_DRC_1_DRC1AA    =0,99990940093994140625Q23 @91+10, expected decimal, hex, or Qfixed number, found: 0,99990940093994140625Q23.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(7099): Incorrectly formed directive For directive .coeff_miniDSP_D  DRC_1_DRC_1_DRCAD     =0,00001132488250732421875Q23   @91+11, expected decimal, hex, or Qfixed number, found: 0,00001132488250732421875Q23.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(7100): Incorrectly formed directive For directive .coeff_miniDSP_D  DRC_1_DRC_1_DRC1AD    =0,99998867511749267578125Q23 @91+12, expected decimal, hex, or Qfixed number, found: 0,99998867511749267578125Q23.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(9074): Incorrectly formed directive For directive .coeff_miniDSP_D  ToneGenerator_1_alpha          =0,99999988079071044921875M1        @4+1, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(9276): Incorrectly formed directive For directive .coeff_miniDSP_D   Stereo_Mixer_1_MixGain1   =0,99999988079071044921875M1  @0, expected decimal, hex, or Qfixed number, found: 0,99999988079071044921875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(9282): Incorrectly formed directive For directive .coeff_miniDSP_D   Stereo_Mixer_1_MixGain2   =0,19999992847442626953125M1 @0+1, expected decimal, hex, or Qfixed number, found: 0,19999992847442626953125M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(9398): Incorrectly formed directive For directive .coeff_miniDSP_D            Int4xOut_1_HPF_n0          = 0,999725341796875M1       @106, expected decimal, hex, or Qfixed number, found: 0,999725341796875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(9399): Incorrectly formed directive For directive .coeff_miniDSP_D            Int4xOut_1_HPF_n1          = -0,999725341796875M1       @107, expected decimal, hex, or Qfixed number, found: -0,999725341796875M1.  Error:The whole part could not be parsed as an integer.
Error: aic_gen.asm(9400): Incorrectly formed directive For directive .coeff_miniDSP_D            Int4xOut_1_HPF_d1          = 0,999481201171875M1       @108, expected decimal, hex, or Qfixed number, found: 0,999481201171875M1.  Error:The whole part could not be parsed as an integer.
55 errors detected
Assembler was terminated.
Summary: 55 Error(s)
Code generation terminated on main Rate44
Build failed.
Does anybody can explain me what is going wrong ?
Sébastien
