Part Number: TPA2028D1
Other Parts Discussed in Thread: TPA2026D2
Could you please tell me the pwm modulation method(AD mode or BD mode or 1SPW mode) for TPA2028D1 ?
Kato
Hi José-san,
Thank you for your reply.
It seems that the pwm modulation method for TPA2028D1 isn't same with TPA2026D2 one when observing the single-ended output after the LC filter with the oscilloscope.
Is my understanding correct that it is difference between the pwm modulation methods ?
Kato
Hi José-san,
For TPA2028D1 a half wave rectified signal is output from each channel if inputting the 1kHz sine wave when observing the single-ended output after the LC filter with the oscilloscope.
On the other hand, for TPA2026D2 a sine wave is output in the same condition.
So, I understand that it is difference between the pwm modulation methods.
Kato
Hi José-san,
I evaluated TPA2028D1YZFEVM, so please see the following capture.
As I mentioned above, a half wave rectified signal is output from each channel in TPA2028D1.
* yellow : OUTP, blue : OUTM, red : OUTP - OUTM
This phenomenon isn't issue, so I would like to tell you only that the single-ended output waveform for TPA2028D1 isn't same with TPA2026D2 one.
Kato
