Part Number: TPA6120A2
Other Parts Discussed in Thread: OPA4134, PCM1792A
Could you please tell me the power-on sequence which you would recommend if using TPA6120A2 with the following configuration ?
I have a concern for the pop noise when applying the power supply voltage.
For instance, my considering is shown as below.
Power-on Sequence : TPA6120A2 ---> ON, OPA4134 ---> ON, PCM1792A ---> ON
Power-off Sequence : PCM1792A ---> OFF, OPA4134 ---> OFF, TPA6120A2 ---> OFF
Kato
