I was hoping I could get some advice on how to configure the TLV320AIC3268 to receive over I2S to the Class D SPKM and SPKP. My specifications are below and register values are attached but I can't seem to get it working. I was hoping someone could confirm I have my register values set correctly.
I2S Specifications:
- Using ASI#2 , BCLK2, WCLK2, DIN2, DOUT2
- BCLK2 to be used as the DAC_CLKIN
- TLV320AIC3268 is the I2S Slave
- Left justified
- MSB of SD data occurs in the second SCLK period
- When WS is high, SD data is right channel
- 17-bit data is rounded down to 16-data.
- Sample Frequency 44.1kHz
- 32 bit
Script to set registers:
######################################################################################### # Audio Serial Interface #2 to Class-D Speaker # LOL and LOR are mixed 0dB/0dB to convert stereo to mono # AVDDx_18, HVDD_18, CPVDD_18 = 1.8V; IOVDDx_33, RECVDD_33 = 3.3V # SVDD, MICBIAS_VDD (JP37 1-2 + JP44 2-3), SPK_V = 5V, DVdd_18 = 1.8V # No Master Clock, BLKC2 to be used as CLKIN # MCLK = NA, BCLK2 = DAC_CLKIN = 1.4112MHz, Fs = 44.1kHz # PLL Disabled, DOSR = 32, # Audio Serial Interface #2 signals routed to DIN2 (DIN), BCLK2 (BCLK), DOUT2 (DOUT), # WCLK2 (WCLK) - Codec ASI#2 is Slave ######################################################################################### ######################################################################################### # Codec Software Reset ######################################################################################### w 30 00 00 # Initialize to Page 0 w 30 7f 00 # Initialize to Book 0 w 30 01 01 # Initialize the device through software reset d 1 # Delay 1 millisecond ######################################################################################### # FIFO Configuration ######################################################################################### w 30 00 00 # Select Page 0 w 30 7f 78 # Select Book 120 w 30 32 80 # Enable DAC FIFO w 30 7f 64 # Select Book 100 w 30 32 80 # Enable ADC FIFO w 30 7f 00 # Select Book 0 ######################################################################################### # Power and Analog Configuration ######################################################################################### w 30 00 04 # Select Page 4 w 30 77 c0 # Disable miniDSP power-up sync with ASI w 30 00 00 # Select Page 0 w 30 0d 00 10 # Program DOSR = 16 -AB w 30 14 10 # Program AOSR = 16 -AB w 30 00 01 # Select Page 1 w 30 01 00 # Disable weak AVDD to DVDD connection, make analog supplies available ######################################################################################### # For BiQuad Configuration see Script '0.1.txt' ######################################################################################### b "Device Initialized and in Standby" ######################################################################################### # Clock configuration # MCLK = NA, WCLK = 44.1 kHz (slave) # BCLK = 44.1kHz * 32bit * 1 channel = 1.4112 MHz ######################################################################################### w 30 00 00 # Select Page 0 w 30 04 40 # Set DAC_CLKIN as BCLK -AB w 30 0b 81 # NDAC = 1 w 30 0c 82 # MDAC = 2 #BCLK = 44.1kHz * 32bit * 1 channel = 1.4112 MHz w 30 0d 00 # Program the OSR of DAC to 16 to get w 30 0e 10 # DAC_FS = DAC_MOD_CLK / DOSR = 1.4112MHz / 32 = 44.1kHz -AB ######################################################################################### # Audio Serial Interface Routing Configuration - Audio Serial Interface #2 # ASI #2 connected to BCLK2, WCLK2, DIN2, and DOUT2 pins ######################################################################################### w 30 00 04 # Select Page 4 w 30 11 18 # Audio Serial Interface #2 = I2S mode, 32-bit -AB w 30 1a 00 # For Audio Serial Interface #1, # Select BCLK2 as BCLK input and WCLK2 as WCLK input w 30 17 01 # Route ADC data to Audio Serial Interface #2 w 30 18 50 # ASI#2 Left Channel data sent to Left Channel DAC, # ASI#2 Right channel data sent to Right Channel DAC w 30 45 04 # Select WCLK2 pin as WCLK for Audio Serial Interface #2 w 30 46 04 # Select BCLK2 pin as BCLK for Audio Serial Interface #2 w 30 47 22 # Select DOUT2 pin as DOUT for Audio Serial Interface #2 w 30 48 20 # Select DIN2 pin as DIN for Audio Serial Interface #2 w 30 76 16 # Only ASI#2 Routed to DAC miniDSP Data Input 1 ######################################################################################### # Signal Processing Settings ######################################################################################### w 30 00 00 # Select Page 0 w 30 3c 01 # Set the DAC Mode to PRB_P1 ######################################################################################### # Output Channel Configuration ######################################################################################### w 30 00 01 # Select Page 1 w 30 03 00 # Set PTM mode for Left DAC to PTM_P3 (default, writing here optional) w 30 04 00 # Set PTM mode for Right DAC to PTM_P3 (default, writing here optional) w 30 16 c3 # Enable DAC to LOL/R routing and power-up LOL/R w 30 2E 00 # Route LOL to SPK @ 0dB -AB w 30 2F 00 # Route LOR to SPK_RIGHT_CH_IN @ 0dB -AB w 30 30 11 # Set SPK Gain @ 6dB, unmute SPK_RIGHT_CH_IN w 30 2D 06 # Power-up SPK, route SPK_RIGHT_CH_IN to SPK w 30 00 00 # Select Page 0 w 30 3f c0 # Power up the Left and Right DAC Channels w 30 40 00 # Unmute the DAC digital volume control d 40 # Wait for reference to power up b "Device in Operational Mode" ######################################################################################### # For Power Down Sequence see Script '0.2.txt' #########################################################################################
I2C log setting registers:
# ----------------------------- # LOG START Thu Jul 27 14:54:59 2017 # ----------------------------- # LOG START Thu Jul 27 15:12:02 2017 w 30 00 00 w 30 7f 00 w 30 01 01 w 30 00 00 w 30 7f 78 w 30 32 80 w 30 7f 64 w 30 32 80 w 30 7f 00 w 30 00 04 w 30 77 c0 w 30 00 00 w 30 0d 00 20 w 30 14 20 w 30 00 01 w 30 01 00 w 30 00 00 w 30 04 40 w 30 0b 81 w 30 0c 82 w 30 0d 00 w 30 0e 20 w 30 00 04 w 30 11 18 w 30 1a 00 w 30 17 01 w 30 18 50 w 30 45 04 w 30 46 04 w 30 47 22 w 30 48 20 w 30 76 16 w 30 00 00 w 30 3c 01 w 30 00 01 w 30 03 00 w 30 04 00 w 30 16 c3 w 30 2e 00 w 30 2f 00 w 30 30 11 w 30 2d 06 w 30 00 00 w 30 3f c0 w 30 40 00 w 30 00 00 w 30 7f 00 w 30 01 01 w 30 00 00 w 30 7f 78 w 30 32 80 w 30 7f 64 w 30 32 80 w 30 7f 00 w 30 00 04 w 30 77 c0 w 30 00 00 w 30 0d 00 20 w 30 14 20 w 30 00 01 w 30 01 00 w 30 00 00 w 30 04 40 w 30 0b 81 w 30 0c 82 w 30 0d 00 w 30 0e 20 w 30 00 04 w 30 11 18 w 30 1a 00 w 30 17 01 w 30 18 50 w 30 45 04 w 30 46 04 w 30 47 22 w 30 48 20 w 30 76 16 w 30 00 00 w 30 3c 01 w 30 00 01 w 30 03 00 w 30 04 00 w 30 16 c3 w 30 2e 00 w 30 2f 00 w 30 30 11 w 30 2d 06 w 30 00 00 w 30 3f c0 w 30 40 00 w 30 00 00 w 30 7f 00 w 30 01 01 w 30 00 00 w 30 7f 78 w 30 32 80 w 30 7f 64 w 30 32 80 w 30 7f 00 w 30 00 04 w 30 77 c0 w 30 00 00 w 30 0d 00 10 w 30 14 10 w 30 00 01 w 30 01 00 w 30 00 00 w 30 04 40 w 30 0b 81 w 30 0c 82 w 30 0d 00 w 30 0e 10 w 30 00 04 w 30 11 18 w 30 1a 00 w 30 17 01 w 30 18 50 w 30 45 04 w 30 46 04 w 30 47 22 w 30 48 20 w 30 76 16 w 30 00 00 w 30 3c 01 w 30 00 01 w 30 03 00 w 30 04 00 w 30 16 c3 w 30 2e 00 w 30 2f 00 w 30 30 11 w 30 2d 06 w 30 00 00 w 30 3f c0 w 30 40 00
