Part Number: TLV320AIC3254EVM-K
Hello TI,
I have been trying to implement a noise gate algorithm using pure path studio and there seems to be an error, i had the same process flow the other day and it was working fine could you please help me interpret this error. I am attaching my process flow along with the error
My Noise Gate settings are:
NR_Level-0.34576685703125
Reg_Smspeed- 0,99687987773020813992
NG_Threshold-3.981098
This is the error that i recieve:
Gerating code for base_main_Rate16 .. assembling ...MemoryType usage: miniDSP_A_coeff: 5, miniDSP_A_data: 2, miniDSP_A_instr: 7, miniDSP_A_instr_alloc: 7, miniDSP_A_cycles: 7, miniDSP_A_cycles_alloc: 7,miniDSP_D_coeff: 67, miniDSP_D_data: 120, miniDSP_D_instr: 292, miniDSP_D_instr_alloc: 297, miniDSP_D_cycles: 238, miniDSP_D_cycles_alloc: 6137
Error: aic_gen.asm(1082): Address Expected : NoiseGate_1_one_m_beta - must be a Coefficient variable reference or a hex, decimal, or binary integer
1 error detected
Assembler was terminated.
Summary: 1 Error(s)
Code generation terminated on base main Rate16
Build failed
Thank You,
