Other Parts Discussed in Thread: PCM2903C, DRV603
We would like to use PCM2903C audio codec chip in our design where the codec chip is interfaced with on-board host processor.
The design requirement is converting digital audio data(from host processor)via USB into analog audio output.
I have seen application circuit.I need some clarifications on that
* Analog & Digital power pins can be sourced from single common supply or do i need to isolate analog and digital voltages
* Whats the purpose of using 1 Mohm resistor pulling down to ground for Vbus line ?
* Any recommendation for unused pins since we have many pins that are not used in our current application.
