What should I do with the unused Vin pins of PCM1851A? I wasn't able to find this information in the datasheet.
thanks
Hi, Rifo,
This device accepts the use of a terminating resistor connected to VrefS as an option, Using a cap to AC couple to GND is a common technique that also can be used for this device. The effect should be the same for either case.
-Diego Meléndez López
Audio Applications Engineer
