TLV320ADC3101EVM-K: Problem for download PurePath
Guru 11170 points
Part Number: TLV320ADC3101EVM-K
Hi E2E,
When download the PurePath from "mySecure Software" to my PC, file name extension is not exe.
If I change the file name extension to exe on my PC, are you concerned?
ACGUY
  • Hi, Acguy,
    This seems strange, I have verified that the file available for download from mySecure Software site is a .exe, there should be no need of changing the extension. Can you please verify that the name of file you downloaded is setup_PurePath_Studio_Portable_Audio_MiniDSP_v5.95_build1_rev35815?.
      -Diego Meléndez López
       Audio Applications Engineer
  • Hello Diego,
    Thank you for reply.
    That file name is consistent with that which you indicate, however I downloaded file has not extension.
    If I change or add an extension, the file not work?
    ACGUY
  • Hi, Acguy,
    The file you downloaded should be detected by your OS as an Application. You can try changing the extension, I don't think the file will get affected.
