Part Number: PCM1796
Tool/software: Linux
Hi there!
I'm new with PCM1796 DAC and have some issues to work with it. I've defined my dts in order to enable I2C working with it, is connected to the power supply but i can't detect the device when use i2cdetect...
I've read in the datasheet about an internal reset if not detects 1024 system clock cycles. Currently, is not connected to the I2S bus so no system clock is available. Could be this the problem to get it working??
In addition, is there any ALSA driver available for this codec?
Best Regards!
