Linux/tlv320aic3106: tlv320aic3106
Part Number: TLV320AIC3106
Other Parts Discussed in Thread: TPA2005D1,
Tool/software: Linux
Hello Sir ,
I am using tlv320aic3106 audio CODEC IC and a TPA2005D1 amplifier to get the speaker output on line out (LEFT_LO+) . I don't have much experience with the "audio routing" and "register configuration".what all registers do we need to alter to make the configuration proper. Could you help me with the routing and the registers we should focus to make the configuration proper.
with regards
pranav
  • Hi, Pranav,
    The audio routing of this device is easily explained in this app note. Also, you can find a configuration example there. The document is specific for a device of the same family as the 'AIC3106. Basically, you need to configure the routing, turn the line drivers ON and finally, turn the DAC ON and unmute the blocks to start streaming the digital audio to the line output. Please take a look to the mentioned app note and let me know if you have further questions.
      -Diego Meléndez López
       Audio Applications Engineer
