Other Parts Discussed in Thread: TAS2552
Tool/software: Linux
We want to use TAS2552 Amplifier and Converter with an ARM based embedded Linux.
However, after configuring DTS there is a ALSA Souncard, but aplay gives an error:
aplay: set_params:1305: Channels count non available
We configured two Items in DTS:
tas2552_sound: tas2552-sound {
status = "okay";
compatible = "simple-audio-card";
model = "ti-tas2550";
audio-routing =
"Ext Spk", "OUT" ,
"Int Mic", "IN";
simple-audio-card,format = "i2s";
simple-audio-card,name = "P5tas2552";
simple-audio-card,cpu {
sound-dai = <&i2s0>;
simple-audio-card,codec {
sound-dai = <&tas2552>;
&i2c2 {
status = "okay";
clock-frequency = <400000>;
tas2552: tas2552@40 {
compatible = "ti,tas2552";
reg = <0x40>;
#sound-dai-cells = <0>;
vbat-supply = <&vdda_codec>;
iovdd-supply = <&vccadc_ref>;
avdd-supply= <&vccadc_ref>;
This is an excerpt of messages during boot of the Board:
[ 0.189809] Advanced Linux Sound Architecture Driver Initialized.
[ 4.876924] asoc-simple-card hdmi-codec: i2s-hifi <-> ff8a0000.i2s mapping ok
[ 4.888926] asoc-simple-card tas2552-sound: tas2552-amplifier <-> ff880000.i2s mapping ok
[ 5.131152] ALSA device list:
[ 5.139035] #0: HDMI-CODEC
[ 5.146635] #1: P5tas2552
[ OK ] Reached target Sound Card.
To use TAS2552 as default, I created /etc/asound.conf:
# cat /etc/asound.conf
pcm.!default {
type hw
card 1
ctl.!default {
type hw
card 1
Accessing with Alsa-Tools:
# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: HDMICODEC [HDMI-CODEC], device 0: ff8a0000.i2s-i2s-hifi i2s-hifi-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: P5tas2552 [P5tas2552], device 0: ff880000.i2s-tas2552-amplifier tas2552-amplifier-0 []
Subdevices: 1/1
# # aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
sysdefault:CARD=HDMICODEC
HDMI-CODEC,
Default Audio Device
sysdefault:CARD=P5tas2552
P5tas2552,
# amixer set 'Speaker Driver' 100%
Simple mixer control 'Speaker Driver',0
Capabilities: pvolume pvolume-joined
Playback channels: Mono
Limits: Playback 0 - 31
Mono: Playback 31 [100%] [24.00dB]
# amixer set 'Input selection' "Digital"
Simple mixer control 'Input selection',0
Capabilities: enum
Items: 'Digital' 'Analog'
Item0: 'Digital'
# aplay -v -c 1 -t raw /usr/share/sounds/alsa/Noise.wav
Playing WAVE '/usr/share/sounds/alsa/Noise.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
Any hints will be greatly appreciated.
