Difference between Compressed and non Compressed PCM
Hello!
I need to know the difference between Compressed and non Compressed PCM files.
  • Hi, Zain,
    As far as I know, the non compressed PCM is a class of audio format, that stores the audio waveform "as is", without processing. Compressed PCM is not actually well defined, but can be seen as a common way to call any format where the processing of the audio data is done to reduce the file size. Maybe someone in the forum can give you a more accurate response :).
      -Diego Meléndez López
       Audio Applications Engineer
