LM4911Q-Q1: Minimum road impedunce
Part Number: LM4911Q-Q1
What ohm is minimum road impedunce of LM4911-Q1?
Our situation is below.
Our customer understand that usually headphone impedunce is 16 or 32 ohm.
But end customer is requesting them to 10 ohm as minimum load impedunce.
Y.Hirata
  • Hi Hirata-san,
    Going out of data sheet spec is not recommended, as we cannot guarantee the device performance for situations outside of the specs.
    You could try and test the device performance for a lower load, however the results may be different from data sheet data.
    -Ivan Salazar
    Applications Engineer - Low Power Audio & Actuators
