TPA2028D1: Relation between Resister Setting & EN Signal
Part Number: TPA2028D1
Dear, Sir.
My customer is considering to apply TPA2028D1 for their system.
They would like to confirm ;
1. Will the internal resister setting via I2C be maintain when EL=L(Disable)?
2. Will the resister setting return to defaut value be happened at power-on stage?
Sorry to ask this kind of matter, but these are not described on the datasheet.
So they would like to double-confirm these. Please give your advice.
H. Sakai
  • Hi Sakai-san,
    I can't understand you very well. Could you explain me in detail each question?
    Best Regards
    José Luis Figueroa
    Audio Applications Engineer
  • Dear, Jose-san.
    Thank you for your reply.
    The internal resister on TPA2028D1 is set(written) by external MCU or DSP  via I2C.
    Question is ;
    1. The written resister value never return to default value by EN signal become HIGH toLOW?
    2. When the written resister value return to default value?
    H. Sakai
  • Sakai-san,
    1) In fact, If you toggle the EN signal the written register map values return to the default values.
    2) The default register map values return by a power cycle or if you toggle the EN signal.
    Best Regards
    José Luis Figueroa
  • Dear, Jose-san.
    Thank you for your current support.
    I have checked another thread like as below;
    e2e.ti.com/.../622567
    I worry about what is the best procedure to eliminate the pop noise.
    Assuming based on above thread, the procedure would be ;
    1. Power supply start up(OFF => ON).
    2. Wait some msec.
    3. Set the audio signal.
    4. EN pin is enabled.
    1. I wonder my understanding is correct?
    2. If the customer don't execute #1(Powewr supply OFF =>ON), What is the best procesure to eliminate the pop noise?
    Please give your advice and help.
    H. Sakai
