Part Number: TLV320AIC3256EVM-U
Other Parts Discussed in Thread: TLV320AIC3120
I am working on a TLV320AIC3256EVM-U module to determine if it will work for an audio system for hearing impaired people. I have applied a 1 KHz sine wave (100 mVp-p) to the line-in input and monitored the headphone output on my scope. Both analog bypass circuits work fine. My questions are:
1) If I use the ADC mini-dsp for signal processing, can I send the output directly to the DAC to produce an output signal?
2) If so, how do I do this? The documentation calls the ADC part the record path and the DAC the playback path.
3) I don't want to record anything. I just want to filter an input signal, adjust the gain at different frequencies, and produce an analog output signal. For example, the gain of the audio output at 1 KHz may be 20 db, but the gain at 10 KHz may be 80 db. Will the AIC256 produce a 60 db audio output signal gain difference from 1 KHz to 10 KHz? An equalizer may not provide this differential.
4) My initial thought was to use the 5 BiQuad filters with 5 different fc values to do this. Will this provide the gain difference?
5) What is the best TI product for doing this for a portable, battery-powered audio system?
6) Does TI do audio system designs such as the evaluation modules, or do have external design houses do the designs?
7) Can you recommend a design firm if TI does not do board designs? I would like to contact them. If TI does do such designs, can you send email contact information?
Thanks and best regards,
Bob Rountree
