Ambient Noise (Sound) Compensation -- TAS5720M
Other Parts Discussed in Thread: TAS5720M
Hi All,
We are design an Alarm unit for one of our customer. We are planning to use TAS5720M in our application to interface with Atmel controller which supports SSC (Synchronous Serial communication).
We have few concerns, could someone please help me in fixing the same.
1. Does TAS5720M supports for interfacing with SSC signals. (TD - Transmit data, TF - Transmit Frame, TK - Transmit Clock)
2. We need to measure ambient noise level ( Sound) in the cabin. And depending upon the noise level we need to adjust the output of the Speaker. We are not able to find an solution which would fit out application. It would be great help if some one can help using with hardware design for measuring the ambient noise. We want to take 8-10 samples every 10Sec, Average the samples to get the final db level of the noise. Same db level will be added to the base level of the Amplifier output.
Chiru
