Part Number: TAS5754M
Other Parts Discussed in Thread: TAS5756MDCAEVM, , TAS5756M
Hi Team,
Customer is designing the TAS5754. They are some noise issues on customer board. (play 1k tone from NB, the TAS5754 output the robot sound mixed with the normal 1k tone)
The Audio source waveform is perfect that verified by scope. The I2C command is coorect which verified by EVM I2C host.
We found the audio source frequency on MCLK is 3.072MHz.
The audio source send the out the frequency as follow.
The MCLK and BCLK did not tie together.
Can you please check the MCLK can support 3.072MHz? What will happen if customer using the following audio source?
1. MCLK: 3.072MHz
2. BLCK: 3.072MHz
3. WCLK: 48KHz
SHH
