Other Parts Discussed in Thread: TLV320AIC3204,
Hi expert!
I use aic3254 for slave in my system.
Main MCU make MCLK ( 4MHz), WCLK(16 KHz), BCLK (512KHz) and 16bit data/16bit frame. Also, main MCU configures the AIC3254.
But there is no DOUT from aic3254.
I configured registers as below refer to "Design and Configuration Guide for the TLV320AIC3204 and TLV320AIC3254 Audio Codecs"
Could you please suggest the way to correct the configuration?
And, I use the PPS flow based on Rate 16 KHz as below. Is there any effect to I2S?
Best regards
