Hi,TI
I have a TAS2560 EVM board, and I want to get the amplifier's sensed voltage and current data.
I set TAS2560 in mode 2 (PCM input playback + PCM IVSense output), but I do not find the PCM IVSense output format in the TAS2560 datasheet. I just find figure 52(Mode 2 Processing Block Diagram), so how L/R Mix work?
In addition I don't know the resolution about the V/I ADC and the PCM output format, so I can't identify significance bits in the transmit data.
finally, I try to mute VSense and ISense (set MUTE_ISNS and MUTE_VSNS to 1) , in my opinion DOUT should always be 0V (When I mute the audio, DOUT is always 0V), but I get the wave as shown below
the green wave is DOUT and the purple wave is WCLK, what is happening ? What is this data?
