PCM5142: Purepath bin files
Part Number: PCM5142
dear ti-support,
pls could you help me with PurePath 5.95 process flow PCM5142 application of Allo-Piano DAC.
there are strange anomalies starting at 1k, even straight i/o throughput without any objects is showing the same effect. if using the bin files supplied by allio it works correct.
pls see files attaached. what can i do to get correct output?
best regards
markus
flat.pfw.zip
