Other Parts Discussed in Thread: TLV320AIC3204, TLV320AIC3268
I'm trying to find a way to switch between different audio sources and output I2S. So my idea is that I have multiple audio sources (analog) and one I2S source and I want to switch between them and afterwards output them as I2S. You may ask yourself why in the world I would input I2S and output I2S, but this is only because I want to have single chip switcher (aka use no mux for the I2S signals). So far I found the PCM3186A and initially I though that this might be the chip for me, but then after reading its datasheet I'm not quite sure that it will work for me. My question is: Can the PCM3168A can be used for my task? Is it actually possible to switch between the ADC and I2S input and output the selected signal through the output I2S?
DK
