Part Number: PCM1861
For a test equipment, I am using a PCM1861 in differential input mode.The card that is under test outputs a sinus wave. I then use PCM1861 to convert it into I2S stream and take a 256 point FFT
Sometimes, the cards that I am testing have the P or N line of the differential line missing (due to problems happening in auto assembly) PCM1861 still outputs a valid I2S stream and the FFT of the incoming stream produces correct results.
Is this normal behaviour of PCM1861? Is there a way to detect this anomaly?
thanks a lot for your help
rifo
