Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
TPA3122D2: TPA3122D2
Part Number: TPA3122D2
I have a problem with the shutdown control in mono amplifier that I designed around TPA3122. When the shutdown is off (/SD is high) the amp runs fine. However with some units the shutdown does not turn the chip completely off. The output just gets weak and distorted and the chip starts running a lot warmer. The shutdown pin is connected to the output of a 4069 logic gate. Should the /SD pin have a low pass filter? The board is something that I designed for my students and the problem has occurred with some units but not all of them.
Petteri
