Part Number: PCM5242
Other Parts Discussed in Thread: INA2137
We have an actual design using PCM5242 + TPA6120 + INA2137. Until here everythings works as expected, the problem is when we try to use the balanced output for an external amplifier.
I think there is some impedance problem when connecting balanced lines to the external amp/capture soundcard. This is how we've implemented parts on our design.
Suggested for XLR:
Should we add the 499 resistors plus 1000pf capacitor as suggested on EVM board for XLR on green points or should we tie the output from the points marked on red? If the last one, will that affect the impedance for the TPA and INA devices? Is the INA2137 well connected? (that way works fine)
Thank you!
Oriol.
