PCM1865: Internal CLK
Part Number: PCM1865
XI, XO, SCKI floating is OK?
  • Hi, Ray,
    It would be OK to float the described pins only if the device is configured in slave PLL mode, where the internal clocks are automatically generated from BCLK signal. This will work as long as standard audio clock rates are used.
      -Diego Meléndez López
       Audio Applications Engineer
