Part Number: PCM9211
PCM9211 can support the jitter tolerance in "IEC60958-3" ,so could you please tell me whether PCM9211 can also support the jitter tolerance specification in "AES3" ?
Kato
Kato
Hi, Kato-san,
Sorry for the delayed response, Unfortunately, the engineer in charge of the PCM9211 support is out of the office. The DIR module of this device should comply with the general specifications for the AES3 standard. We will check with the team if specific information for jitter tolerance is available and will get back to you if we find something. As this is an old part designed by a team which is no longer in TI, it would be complicated to get this information, so we appreciate your comprehension.
-Diego Meléndez López
Audio Applications Engineer
Hi Diego-san,
Thank you for your explanation.
I understood, so please let me know if you would find something.
Kato
