Andy Liu SH said:I would recommend you always use 0.22 uF caps. If you use other caps, you might see some problems.
Andy
Dear Andy Liu,
Thank you for the reply.
I would like to know that what kind of problems could be happen if increses from 0.22uF?
Udeni
It has been optimized for 0.22uF caps by our design team. What cap do you want to use instead? I will double check with them. Thanks.
Andy
Thank you for the confirmation.
Noted we will use 0.1 x2 for bootstrap.
I have another question about lowpass filter capacitor value.
TI recommendation is L=10uH and C=0.68uF, But 0.68uF have part delivery problem and we want to use
1uF for mono subwoofer (PBTL) channel. Is it OK?
Noted. Thank you.very much.
>What's the speaker impedance? I will double check.
We are using 3 Ohm speaker for sub woofer.
