Part Number: TLV320DAC32
Hi Team,
Working on a design with the TLV320DAC32EVM and wanted to get some clarification. We are trying to get the most basic functionality out of is before moving to other use case. Starting by getting LINEL or LINER inputs driven on the outputs. Function generator is sourcing a 1kHz tone on the LINER test point on the EVM but there is not tone on the DAC output. Scope shots are attached as well as settings that are being used.
Both the LEFT and RIGHT DAC output path setting is selected as "Mixed with analog inputs" and both DAC paths are set to mute.
Any suggestions as to why we are not seeing 1kHz on any of the outputs.
Ramon
