Part Number: TPA3126D2
I have several options to route my PCB, and wonder what you would do..
1) leave the board as it is now, preamp is protected by GND PLANE SPLIT , high switching currents will flow at the bottom from amplifier to GND connection (the 4x4 pin headers under preamp)
2) make 1 large GND plane at the bottom and reroute the VCC line connections at the right edge op the toplayer , next to the right upper mounting hole and under the speaker connectors.
in this case GND split is removed, then i wonder if high frequency currents will not pass under preamp circuit and cause problems ....
3) or any better proposal then 1 or 2 ?
thank you
