TLV320AIC3262: PCM format
Part Number: TLV320AIC3262
Does TLV320AIC3262 can support below format? thanks!
Sample rate: 8KHz
  • Hi, Ray,
    I am unable to read the characters of second table, is it possible to translate the table?. From the first table, the PCM format used seems strange as it suggests a mono signal over the data bus is sent (128/8=16). The Audio serial interfaces of the AIC3262 are quite flexible, but I would like to know more details about the format you are showing to check if the codec is compatible or not.
      -Diego Meléndez López
       Audio Applications Engineer
