Part Number: TLV320AIC3254
TLV320AIC3254 Application Reference Guide" SLAA408A, pages 122, Noise and Signal debounce time registers.
When checking the values in the datasheet and manually calculating the values we found a mismatch in the debounce time register values:
1/ The default settings 00000 is an undefined value.
2/ the values for the first 3 values appear to be "1" greater than they should be.
3/ following the initial 3 values results in the rest of the table being 1 off.
Would it be possible to get a check on these two registers please. thanks for your help.
