Hello
Below is customer schematics and test waveform. Customer test some board but it happens 3pcs fail board and other units are good. The fail unit looks happen on output L for Woofer speaker that while power up. Then TPA3118D2 of fail units will happen fault then shut down output L to drive. Please refer to below test waveform
Why fail unit happen fault of TPA3118D2 and others unit good to work on woofer speaker? If any suggestion for this issue? Thank you.
Good unit output L waveform:
Fail unit output L waveform
Good unit SPK_AMP_EN
Fail unit SPK_AMP_EN
BR
Patrick
