Other Parts Discussed in Thread: CC3220S
Hi
I need to transfer I2S signal wireless from sensor to PC. what is the simplest electronics to do this?
Thank you!
Hi
Thank you!
Hi Alex,
That is up for you to decide based on your application. If you're leaning towards using Wi-Fi for your application, I would recommend using the CC3220. You can refer to the i2secho example in the CC3220 SDK. Here's the file path to the example: simplelink_cc32xx_sdk_2_20_00_10\examples\rtos\CC3220S_LAUNCHXL\drivers\i2secho
If you're leaning towards Bluetooth, you can check out TI's portfolio of Bluetooth Low Energy devices here.
Alexis
