Hi,our customer use TPA3255 design for Trolley audio,now meet encountered 450KHZ running frequency and output large ripple. could you help check it and give some suggestions for us to debug it,tks!
Hi, Justin
if the Fpwm is 450khz , the ripple is normal,however, we find the Fpwm will be changed to 620khz automatic during aging test Instead of 450khz,but the R(FREQ_ADJ) is used 30K ohms,only we use 36K ohms can make the Fpwm change to 450khz again, but the recommended resistance is 29.7K~30.3K ohms,This is a normal phenomenon?if the Fpwm is be changed,it will also increase output ripple. pls help check it and give some suggestions,tks!
