TAS5754M: Is there any Gain setting to avoid the Analog output signal clipping.
Part Number: TAS5754M
Dears:
Could you kindly help to check the below issue:
1. There is clipping wave with debugging of the microphone array algorithm, when the speaker microphone is recorded and recovered and after analyzing the recording signal and the recovery signal. And the input playback source is 0dBFS music.
Is there any advice to eliminate the clipping phenomenon through TAS5754M's setting?
2. Are there any registers about EQ enable, EQ disable, DRC enable, DRC disable? Since want to write registers to open and close EQ and DRC.
3. How much is the Gain before entering EQ process generally? Is there any setting about Gain or has the function?
4. If we want to increase the volume, is there any Gain setting to avoid the Analog output signal clipping.
