I would like to keep my TAS5630 in reset as a default state after power on. Could I simply pull-down this line with a resistor? What resistor value would you prefer for that? The input is not detailed documented in the TAS5630 data sheet.
After power on I will start the system from 3V3 µC. Is 3V3 enough to deactivate the RESET line of the TAS5630. What is the RESET input threshold? I didn't find it in data sheet...
Cheers!
Tomasz
