Hi Team,
Please kindly help on these questions. Many thanks.
According to below link comment: https://e2e.ti.com/support/audio/f/6/t/720285?tisearch=e2e-sitesearch&keymatch=TLV320ADC3101%20dsp
ADC3101 has limited miniDSP resources, so it can not support Reverb or Echo effect by TI embedded algorithms.
The Echo and reverb effects may be created manually using the basic miniDSP blocks available in PPS, where user can customize the process flow according to the available resources of the ADC3101's miniDSP.
Q1: Does it means customer can input their own algorithms by PPS tool to achieve Reverb or Echo effect, as long as the algorithm won't over ADC3101's miniDSP ability?
Q2: We want Reverb or Echo effect on one mic input, then mix with another line in, then I2S output. Can ADC3101 do this behavior?
Q3: Are there any ADC suggestion have DSP that have TI embedded algorithm can achieve Reverb or Echo effect?
Q4: Could you help to list a simple functions list that ADC3101's miniDSP can do by TI embedded algorithm?
Many thanks
