TPA3255: Maximum Peak Power Rating
Part Number: TPA3255
What is the maximum peak power rating for the TPA3255.  With a multi-carrier transmit signal power spikes can occur.  Would like to know how to specify the peak to average power ratio for the device.
  • Hi John,
    Could you please help to give us more info about the issue that "With a multi-carrier transmit signal power spikes can occur"? Usually the transient max output power depends on the OC THR on the AMP device, while the continuous outpout power more depends on the system thermal performance.
    Shawn Zheng
