TAS5825M: Question of TAS5825 Programming Sequence with Checksum
Part Number: TAS5825M
Hi Sirs,
In order to enable TAS5825 with proper I2C programming, Can we write the TAS5825 with customer's proposed programming sequence?
1. Write TAS5825 CFG with the last four lines (as we marked in the below picture) removed.
2. Verify CRC or XOR checksum values without the last four lines
3. If checksum passed, than write the last four lines to enable TAS5825.
Thank you and Best regards,
Wayne Chen
11/05/2018
