Part Number: TAS2770EVM
Other Parts Discussed in Thread: TAS2770
I am initially trying to send a signal to the amplifier and read out the voltage and signals using Audacity.
I have tried several different combinations of USB audio settings as well as TDM settings. With some combinations of settings I can sucessfully read the current signal. However, I have never been able to read the votlage or any of the other signals such as Die Temperature, Gain, etc. They usually read out completely zero (not even any normal white noise) or, depending on the settings, "noise" that is very high in amplitude (sometimes appering similar to square wave). This high amplifitude "noise", if present, is even present when no stimulus is played.
How can I sucessfually read out both the current and voltage signals over USB audio?
Thank you.
