TLV320AIC3204: DVDD
Part Number: TLV320AIC3204
Hi team,
When the internal LDO is used, can we use the DVDD power supply as also a reference voltage for other devices within 0.2mA(max)? We would like to use DVDD for not only an internal power supply but also a reference voltage for other devices.
Ishida
  • Hi, Jun,
    Using the on-chip generated DVDD to power other devices is not recommended, the internal LDO is optimized to power-up the internal circuitry of the codec only, using it to power external components may lead to device malfunction, unexpected behavior or performance issues.
      -Diego Meléndez López
       Audio Applications Engineer
