Part Number: PCM1861EVM
Other Parts Discussed in Thread: PCM1861, PCM1860, PCM1865
If i have find a corruption problem of the the firmware of the USB-I2X board, how do i cope with solve ?
Hi, Gyuhag,
Welcome to E2E, thanks for your interest in our products!.
You can follow the steps of this document to re-program the EEPROM on the USB-I2X board.
-Diego Meléndez López
Audio Applications Engineer
Thanks for your document and kindness of re-program procedure.
I did good job for my re-programming the EEPROM but PurPath Consol2 App program have no identify FWID.
If you have any related of "PCM186X_v2.1_rev34705" firmware, please e-mail to me ?
Actually, i had it try the program file(USB-AudioEVM0354_48KHZ.bin) inside the SLOC305's image folder to EEPROM .
Gyuhag,Kim
Hi, Gyuhag,
The FWID is not programmable with the tools provided on the document I pointed out. FWID is used as a way to identify which EVM is connected to the GUI, but should not prevent the EVM evaluation. If you click on Connect as PCM186x, you should be able to open the PCM1861 GUI and evaluate the device.
