Part Number: TAS5753MD
Hello TI Team,
we are working on a new project with the TAS5753MD. Actually, we've got troubles to get some sound of it..
We ensured that the Start-Up and Power-Down sequences work properly - as mentioned in the datasheet. The result: PWM with 50% duty cycle on the SPK_OUTx.
Probably, its due to the configuration we did. For this reason, we did a whole readout of the configuration registers of the TAS (attached riio.log) after 10 secs in normal operation mode.
Further information:
- Our I2S stream: 16bit wordlenth (permanently running)
- MCLK connected to the SCLK pin
Can you recognize which configuration we've missed?
11/28/2018 08:48:56 PM Application Starting 11/28/2018 08:48:58 PM 20:48:58.53 detected falling edge on GPIO: 23 11/28/2018 08:48:58 PM Trying to read data block from slave transmitter 11/28/2018 08:48:58 PM Total Byte blocks recieved: 1 11/28/2018 08:48:58 PM --------------------Recieved-------------------- 11/28/2018 08:48:58 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:48:58 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:48:58 PM Encoder_pos_byte: Hex: 0x0004 Decimal: 4 11/28/2018 08:48:58 PM Knob1_bytes: Hex: 0x0c0f Decimal: 3087 11/28/2018 08:48:58 PM Knob2_bytes: Hex: 0x0cdb Decimal: 3291 11/28/2018 08:48:58 PM Knob3_bytes: Hex: 0x0c80 Decimal: 3200 11/28/2018 08:48:58 PM Source_bytes: Hex: 0x0002 Decimal: 2 11/28/2018 08:48:58 PM -----------------------End----------------------- 11/28/2018 08:48:58 PM 11/28/2018 08:48:58 PM 20:48:58.95 detected falling edge on GPIO: 23 11/28/2018 08:48:58 PM Trying to read data block from slave transmitter 11/28/2018 08:48:58 PM Total Byte blocks recieved: 2 11/28/2018 08:48:58 PM --------------------Recieved-------------------- 11/28/2018 08:48:58 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:48:58 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:48:58 PM Encoder_pos_byte: Hex: 0x0003 Decimal: 3 11/28/2018 08:48:58 PM Knob1_bytes: Hex: 0x0c0f Decimal: 3087 11/28/2018 08:48:58 PM Knob2_bytes: Hex: 0x0cd7 Decimal: 3287 11/28/2018 08:48:58 PM Knob3_bytes: Hex: 0x0cc7 Decimal: 3271 11/28/2018 08:48:58 PM Source_bytes: Hex: 0x0002 Decimal: 2 11/28/2018 08:48:58 PM -----------------------End----------------------- 11/28/2018 08:48:58 PM Entered action parser 11/28/2018 08:48:58 PM Encoder position has changed 11/28/2018 08:48:58 PM 11/28/2018 08:48:59 PM 20:48:59.74 detected falling edge on GPIO: 23 11/28/2018 08:48:59 PM Trying to read data block from slave transmitter 11/28/2018 08:48:59 PM Total Byte blocks recieved: 3 11/28/2018 08:48:59 PM --------------------Recieved-------------------- 11/28/2018 08:48:59 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:48:59 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:48:59 PM Encoder_pos_byte: Hex: 0x0002 Decimal: 2 11/28/2018 08:48:59 PM Knob1_bytes: Hex: 0x0c0f Decimal: 3087 11/28/2018 08:48:59 PM Knob2_bytes: Hex: 0x0ca5 Decimal: 3237 11/28/2018 08:48:59 PM Knob3_bytes: Hex: 0x0ccb Decimal: 3275 11/28/2018 08:48:59 PM Source_bytes: Hex: 0x0002 Decimal: 2 11/28/2018 08:48:59 PM -----------------------End----------------------- 11/28/2018 08:48:59 PM Entered action parser 11/28/2018 08:48:59 PM Encoder position has changed 11/28/2018 08:48:59 PM 11/28/2018 08:49:00 PM 20:49:00.81 detected falling edge on GPIO: 23 11/28/2018 08:49:00 PM Trying to read data block from slave transmitter 11/28/2018 08:49:00 PM Total Byte blocks recieved: 4 11/28/2018 08:49:00 PM --------------------Recieved-------------------- 11/28/2018 08:49:00 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:00 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:00 PM Encoder_pos_byte: Hex: 0x0001 Decimal: 1 11/28/2018 08:49:00 PM Knob1_bytes: Hex: 0x0c0f Decimal: 3087 11/28/2018 08:49:00 PM Knob2_bytes: Hex: 0x0c9b Decimal: 3227 11/28/2018 08:49:00 PM Knob3_bytes: Hex: 0x0ccb Decimal: 3275 11/28/2018 08:49:00 PM Source_bytes: Hex: 0x0002 Decimal: 2 11/28/2018 08:49:00 PM -----------------------End----------------------- 11/28/2018 08:49:00 PM Entered action parser 11/28/2018 08:49:00 PM Encoder position has changed 11/28/2018 08:49:00 PM 11/28/2018 08:49:01 PM 20:49:01.35 detected falling edge on GPIO: 23 11/28/2018 08:49:01 PM Trying to read data block from slave transmitter 11/28/2018 08:49:01 PM Total Byte blocks recieved: 5 11/28/2018 08:49:01 PM --------------------Recieved-------------------- 11/28/2018 08:49:01 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:01 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:01 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:01 PM Knob1_bytes: Hex: 0x0bd5 Decimal: 3029 11/28/2018 08:49:01 PM Knob2_bytes: Hex: 0x0cdf Decimal: 3295 11/28/2018 08:49:01 PM Knob3_bytes: Hex: 0x0cca Decimal: 3274 11/28/2018 08:49:01 PM Source_bytes: Hex: 0x0002 Decimal: 2 11/28/2018 08:49:01 PM -----------------------End----------------------- 11/28/2018 08:49:01 PM Entered action parser 11/28/2018 08:49:01 PM Encoder position has changed 11/28/2018 08:49:01 PM 11/28/2018 08:49:03 PM 20:49:03.59 detected falling edge on GPIO: 23 11/28/2018 08:49:03 PM Trying to read data block from slave transmitter 11/28/2018 08:49:03 PM Total Byte blocks recieved: 6 11/28/2018 08:49:03 PM --------------------Recieved-------------------- 11/28/2018 08:49:03 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:03 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:03 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:03 PM Knob1_bytes: Hex: 0x0c0f Decimal: 3087 11/28/2018 08:49:03 PM Knob2_bytes: Hex: 0x0ba0 Decimal: 2976 11/28/2018 08:49:03 PM Knob3_bytes: Hex: 0x0cc7 Decimal: 3271 11/28/2018 08:49:03 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:03 PM -----------------------End----------------------- 11/28/2018 08:49:03 PM Entered action parser 11/28/2018 08:49:03 PM Knob values have changed 11/28/2018 08:49:03 PM Knob2 value has changed 11/28/2018 08:49:03 PM 11/28/2018 08:49:04 PM 20:49:04.19 detected falling edge on GPIO: 23 11/28/2018 08:49:04 PM Trying to read data block from slave transmitter 11/28/2018 08:49:04 PM Total Byte blocks recieved: 7 11/28/2018 08:49:04 PM --------------------Recieved-------------------- 11/28/2018 08:49:04 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:04 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:04 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:04 PM Knob1_bytes: Hex: 0x0bff Decimal: 3071 11/28/2018 08:49:04 PM Knob2_bytes: Hex: 0x0acb Decimal: 2763 11/28/2018 08:49:04 PM Knob3_bytes: Hex: 0x0cb0 Decimal: 3248 11/28/2018 08:49:04 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:04 PM -----------------------End----------------------- 11/28/2018 08:49:04 PM Entered action parser 11/28/2018 08:49:04 PM Knob values have changed 11/28/2018 08:49:04 PM Knob2 value has changed 11/28/2018 08:49:04 PM 11/28/2018 08:49:04 PM 20:49:04.54 detected falling edge on GPIO: 23 11/28/2018 08:49:04 PM Trying to read data block from slave transmitter 11/28/2018 08:49:04 PM Total Byte blocks recieved: 8 11/28/2018 08:49:04 PM --------------------Recieved-------------------- 11/28/2018 08:49:04 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:04 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:04 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:04 PM Knob1_bytes: Hex: 0x0c0f Decimal: 3087 11/28/2018 08:49:04 PM Knob2_bytes: Hex: 0x0937 Decimal: 2359 11/28/2018 08:49:04 PM Knob3_bytes: Hex: 0x0c78 Decimal: 3192 11/28/2018 08:49:04 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:04 PM -----------------------End----------------------- 11/28/2018 08:49:04 PM Entered action parser 11/28/2018 08:49:04 PM Knob values have changed 11/28/2018 08:49:04 PM Knob2 value has changed 11/28/2018 08:49:04 PM 11/28/2018 08:49:05 PM 20:49:05.14 detected falling edge on GPIO: 23 11/28/2018 08:49:05 PM Trying to read data block from slave transmitter 11/28/2018 08:49:05 PM Total Byte blocks recieved: 9 11/28/2018 08:49:05 PM --------------------Recieved-------------------- 11/28/2018 08:49:05 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:05 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:05 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:05 PM Knob1_bytes: Hex: 0x0c0f Decimal: 3087 11/28/2018 08:49:05 PM Knob2_bytes: Hex: 0x07dd Decimal: 2013 11/28/2018 08:49:05 PM Knob3_bytes: Hex: 0x0caf Decimal: 3247 11/28/2018 08:49:05 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:05 PM -----------------------End----------------------- 11/28/2018 08:49:05 PM Entered action parser 11/28/2018 08:49:05 PM Knob values have changed 11/28/2018 08:49:05 PM Knob2 value has changed 11/28/2018 08:49:05 PM 11/28/2018 08:49:05 PM 20:49:05.44 detected falling edge on GPIO: 23 11/28/2018 08:49:05 PM Trying to read data block from slave transmitter 11/28/2018 08:49:05 PM Total Byte blocks recieved: 10 11/28/2018 08:49:05 PM --------------------Recieved-------------------- 11/28/2018 08:49:05 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:05 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:05 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:05 PM Knob1_bytes: Hex: 0x0c0f Decimal: 3087 11/28/2018 08:49:05 PM Knob2_bytes: Hex: 0x069b Decimal: 1691 11/28/2018 08:49:05 PM Knob3_bytes: Hex: 0x0cb7 Decimal: 3255 11/28/2018 08:49:05 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:05 PM -----------------------End----------------------- 11/28/2018 08:49:05 PM Entered action parser 11/28/2018 08:49:05 PM Knob values have changed 11/28/2018 08:49:05 PM Knob2 value has changed 11/28/2018 08:49:05 PM 11/28/2018 08:49:05 PM 20:49:05.74 detected falling edge on GPIO: 23 11/28/2018 08:49:05 PM Trying to read data block from slave transmitter 11/28/2018 08:49:05 PM Total Byte blocks recieved: 11 11/28/2018 08:49:05 PM --------------------Recieved-------------------- 11/28/2018 08:49:05 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:05 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:05 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:05 PM Knob1_bytes: Hex: 0x0c0f Decimal: 3087 11/28/2018 08:49:05 PM Knob2_bytes: Hex: 0x05a2 Decimal: 1442 11/28/2018 08:49:05 PM Knob3_bytes: Hex: 0x0cc7 Decimal: 3271 11/28/2018 08:49:05 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:05 PM -----------------------End----------------------- 11/28/2018 08:49:05 PM Entered action parser 11/28/2018 08:49:05 PM Knob values have changed 11/28/2018 08:49:05 PM Knob2 value has changed 11/28/2018 08:49:05 PM 11/28/2018 08:49:06 PM 20:49:06.9 detected falling edge on GPIO: 23 11/28/2018 08:49:06 PM Trying to read data block from slave transmitter 11/28/2018 08:49:06 PM Total Byte blocks recieved: 12 11/28/2018 08:49:06 PM --------------------Recieved-------------------- 11/28/2018 08:49:06 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:06 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:06 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:06 PM Knob1_bytes: Hex: 0x0bf0 Decimal: 3056 11/28/2018 08:49:06 PM Knob2_bytes: Hex: 0x07a3 Decimal: 1955 11/28/2018 08:49:06 PM Knob3_bytes: Hex: 0x0cc7 Decimal: 3271 11/28/2018 08:49:06 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:06 PM -----------------------End----------------------- 11/28/2018 08:49:06 PM Entered action parser 11/28/2018 08:49:06 PM Knob values have changed 11/28/2018 08:49:06 PM Knob2 value has changed 11/28/2018 08:49:06 PM 11/28/2018 08:49:06 PM 20:49:06.59 detected falling edge on GPIO: 23 11/28/2018 08:49:06 PM Trying to read data block from slave transmitter 11/28/2018 08:49:06 PM Total Byte blocks recieved: 13 11/28/2018 08:49:06 PM --------------------Recieved-------------------- 11/28/2018 08:49:06 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:06 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:06 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:06 PM Knob1_bytes: Hex: 0x0c0f Decimal: 3087 11/28/2018 08:49:06 PM Knob2_bytes: Hex: 0x06a0 Decimal: 1696 11/28/2018 08:49:06 PM Knob3_bytes: Hex: 0x0ccb Decimal: 3275 11/28/2018 08:49:06 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:06 PM -----------------------End----------------------- 11/28/2018 08:49:06 PM Entered action parser 11/28/2018 08:49:06 PM Knob values have changed 11/28/2018 08:49:06 PM Knob2 value has changed 11/28/2018 08:49:06 PM 11/28/2018 08:49:07 PM 20:49:07.49 detected falling edge on GPIO: 23 11/28/2018 08:49:07 PM Trying to read data block from slave transmitter 11/28/2018 08:49:07 PM Total Byte blocks recieved: 14 11/28/2018 08:49:07 PM --------------------Recieved-------------------- 11/28/2018 08:49:07 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:07 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:07 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:07 PM Knob1_bytes: Hex: 0x0d8f Decimal: 3471 11/28/2018 08:49:07 PM Knob2_bytes: Hex: 0x06ab Decimal: 1707 11/28/2018 08:49:07 PM Knob3_bytes: Hex: 0x0cb7 Decimal: 3255 11/28/2018 08:49:07 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:07 PM -----------------------End----------------------- 11/28/2018 08:49:07 PM Entered action parser 11/28/2018 08:49:07 PM Knob values have changed 11/28/2018 08:49:07 PM Knob1 value has changed 11/28/2018 08:49:07 PM 11/28/2018 08:49:07 PM 20:49:07.94 detected falling edge on GPIO: 23 11/28/2018 08:49:07 PM Trying to read data block from slave transmitter 11/28/2018 08:49:07 PM Total Byte blocks recieved: 15 11/28/2018 08:49:07 PM --------------------Recieved-------------------- 11/28/2018 08:49:07 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:07 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:07 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:07 PM Knob1_bytes: Hex: 0x0ed1 Decimal: 3793 11/28/2018 08:49:07 PM Knob2_bytes: Hex: 0x06ab Decimal: 1707 11/28/2018 08:49:07 PM Knob3_bytes: Hex: 0x0cc7 Decimal: 3271 11/28/2018 08:49:07 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:07 PM -----------------------End----------------------- 11/28/2018 08:49:07 PM Entered action parser 11/28/2018 08:49:07 PM Knob values have changed 11/28/2018 08:49:07 PM Knob1 value has changed 11/28/2018 08:49:07 PM 11/28/2018 08:49:08 PM 20:49:08.69 detected falling edge on GPIO: 23 11/28/2018 08:49:08 PM Trying to read data block from slave transmitter 11/28/2018 08:49:08 PM Total Byte blocks recieved: 16 11/28/2018 08:49:08 PM --------------------Recieved-------------------- 11/28/2018 08:49:08 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:08 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:08 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:08 PM Knob1_bytes: Hex: 0x0dbb Decimal: 3515 11/28/2018 08:49:08 PM Knob2_bytes: Hex: 0x06a7 Decimal: 1703 11/28/2018 08:49:08 PM Knob3_bytes: Hex: 0x0ca0 Decimal: 3232 11/28/2018 08:49:08 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:08 PM -----------------------End----------------------- 11/28/2018 08:49:08 PM Entered action parser 11/28/2018 08:49:08 PM Knob values have changed 11/28/2018 08:49:08 PM Knob1 value has changed 11/28/2018 08:49:08 PM 11/28/2018 08:49:09 PM 20:49:09.4 detected falling edge on GPIO: 23 11/28/2018 08:49:09 PM Trying to read data block from slave transmitter 11/28/2018 08:49:09 PM Total Byte blocks recieved: 17 11/28/2018 08:49:09 PM --------------------Recieved-------------------- 11/28/2018 08:49:09 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:09 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:09 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:09 PM Knob1_bytes: Hex: 0x099f Decimal: 2463 11/28/2018 08:49:09 PM Knob2_bytes: Hex: 0x068f Decimal: 1679 11/28/2018 08:49:09 PM Knob3_bytes: Hex: 0x0c70 Decimal: 3184 11/28/2018 08:49:09 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:09 PM -----------------------End----------------------- 11/28/2018 08:49:09 PM Entered action parser 11/28/2018 08:49:09 PM Knob values have changed 11/28/2018 08:49:09 PM Knob1 value has changed 11/28/2018 08:49:09 PM 11/28/2018 08:49:09 PM 20:49:09.54 detected falling edge on GPIO: 23 11/28/2018 08:49:09 PM Trying to read data block from slave transmitter 11/28/2018 08:49:09 PM Total Byte blocks recieved: 18 11/28/2018 08:49:09 PM --------------------Recieved-------------------- 11/28/2018 08:49:09 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:09 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:09 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:09 PM Knob1_bytes: Hex: 0x083f Decimal: 2111 11/28/2018 08:49:09 PM Knob2_bytes: Hex: 0x0677 Decimal: 1655 11/28/2018 08:49:09 PM Knob3_bytes: Hex: 0x0cbf Decimal: 3263 11/28/2018 08:49:09 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:09 PM -----------------------End----------------------- 11/28/2018 08:49:09 PM Entered action parser 11/28/2018 08:49:09 PM Knob values have changed 11/28/2018 08:49:09 PM Knob1 value has changed 11/28/2018 08:49:09 PM 11/28/2018 08:49:10 PM 20:49:10.14 detected falling edge on GPIO: 23 11/28/2018 08:49:10 PM Trying to read data block from slave transmitter 11/28/2018 08:49:10 PM Total Byte blocks recieved: 19 11/28/2018 08:49:10 PM --------------------Recieved-------------------- 11/28/2018 08:49:10 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:10 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:10 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:10 PM Knob1_bytes: Hex: 0x083f Decimal: 2111 11/28/2018 08:49:10 PM Knob2_bytes: Hex: 0x068b Decimal: 1675 11/28/2018 08:49:10 PM Knob3_bytes: Hex: 0x0dbf Decimal: 3519 11/28/2018 08:49:10 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:10 PM -----------------------End----------------------- 11/28/2018 08:49:10 PM Entered action parser 11/28/2018 08:49:10 PM Knob values have changed 11/28/2018 08:49:10 PM Knob3 value has changed 11/28/2018 08:49:10 PM 11/28/2018 08:49:10 PM 20:49:10.44 detected falling edge on GPIO: 23 11/28/2018 08:49:10 PM Trying to read data block from slave transmitter 11/28/2018 08:49:10 PM Total Byte blocks recieved: 20 11/28/2018 08:49:10 PM --------------------Recieved-------------------- 11/28/2018 08:49:10 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:10 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:10 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:10 PM Knob1_bytes: Hex: 0x0837 Decimal: 2103 11/28/2018 08:49:10 PM Knob2_bytes: Hex: 0x0665 Decimal: 1637 11/28/2018 08:49:10 PM Knob3_bytes: Hex: 0x0f0f Decimal: 3855 11/28/2018 08:49:10 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:10 PM -----------------------End----------------------- 11/28/2018 08:49:10 PM Entered action parser 11/28/2018 08:49:10 PM Knob values have changed 11/28/2018 08:49:10 PM Knob3 value has changed 11/28/2018 08:49:10 PM 11/28/2018 08:49:11 PM 20:49:11.29 detected falling edge on GPIO: 23 11/28/2018 08:49:11 PM Trying to read data block from slave transmitter 11/28/2018 08:49:11 PM Total Byte blocks recieved: 21 11/28/2018 08:49:11 PM --------------------Recieved-------------------- 11/28/2018 08:49:11 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:11 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:11 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:11 PM Knob1_bytes: Hex: 0x081f Decimal: 2079 11/28/2018 08:49:11 PM Knob2_bytes: Hex: 0x068b Decimal: 1675 11/28/2018 08:49:11 PM Knob3_bytes: Hex: 0x0d8f Decimal: 3471 11/28/2018 08:49:11 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:11 PM -----------------------End----------------------- 11/28/2018 08:49:11 PM Entered action parser 11/28/2018 08:49:11 PM Knob values have changed 11/28/2018 08:49:11 PM Knob3 value has changed 11/28/2018 08:49:11 PM 11/28/2018 08:49:11 PM 20:49:11.74 detected falling edge on GPIO: 23 11/28/2018 08:49:11 PM Trying to read data block from slave transmitter 11/28/2018 08:49:11 PM Total Byte blocks recieved: 22 11/28/2018 08:49:11 PM --------------------Recieved-------------------- 11/28/2018 08:49:11 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:11 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:11 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:11 PM Knob1_bytes: Hex: 0x083f Decimal: 2111 11/28/2018 08:49:11 PM Knob2_bytes: Hex: 0x067b Decimal: 1659 11/28/2018 08:49:11 PM Knob3_bytes: Hex: 0x0af7 Decimal: 2807 11/28/2018 08:49:11 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:11 PM -----------------------End----------------------- 11/28/2018 08:49:11 PM Entered action parser 11/28/2018 08:49:11 PM Knob values have changed 11/28/2018 08:49:11 PM Knob3 value has changed 11/28/2018 08:49:11 PM 11/28/2018 08:49:12 PM 20:49:12.14 detected falling edge on GPIO: 23 11/28/2018 08:49:12 PM Trying to read data block from slave transmitter 11/28/2018 08:49:12 PM Total Byte blocks recieved: 23 11/28/2018 08:49:12 PM --------------------Recieved-------------------- 11/28/2018 08:49:12 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:12 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:12 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:12 PM Knob1_bytes: Hex: 0x0837 Decimal: 2103 11/28/2018 08:49:12 PM Knob2_bytes: Hex: 0x068e Decimal: 1678 11/28/2018 08:49:12 PM Knob3_bytes: Hex: 0x0970 Decimal: 2416 11/28/2018 08:49:12 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:12 PM -----------------------End----------------------- 11/28/2018 08:49:12 PM Entered action parser 11/28/2018 08:49:12 PM Knob values have changed 11/28/2018 08:49:12 PM Knob3 value has changed 11/28/2018 08:49:12 PM 11/28/2018 08:49:12 PM 20:49:12.44 detected falling edge on GPIO: 23 11/28/2018 08:49:12 PM Trying to read data block from slave transmitter 11/28/2018 08:49:12 PM Total Byte blocks recieved: 24 11/28/2018 08:49:12 PM --------------------Recieved-------------------- 11/28/2018 08:49:12 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:12 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:12 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:12 PM Knob1_bytes: Hex: 0x0835 Decimal: 2101 11/28/2018 08:49:12 PM Knob2_bytes: Hex: 0x0690 Decimal: 1680 11/28/2018 08:49:12 PM Knob3_bytes: Hex: 0x088f Decimal: 2191 11/28/2018 08:49:12 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:12 PM -----------------------End----------------------- 11/28/2018 08:49:12 PM Entered action parser 11/28/2018 08:49:12 PM Knob values have changed 11/28/2018 08:49:12 PM Knob3 value has changed 11/28/2018 08:49:12 PM 11/28/2018 08:49:12 PM 20:49:12.84 detected falling edge on GPIO: 23 11/28/2018 08:49:12 PM Trying to read data block from slave transmitter 11/28/2018 08:49:12 PM Total Byte blocks recieved: 25 11/28/2018 08:49:12 PM --------------------Recieved-------------------- 11/28/2018 08:49:12 PM Start_bytes: Hex: 0xbeaf Decimal: 48815 11/28/2018 08:49:12 PM Buttonstates_bytes: Hex: 0x00cc Decimal: 204 11/28/2018 08:49:12 PM Encoder_pos_byte: Hex: 0x0000 Decimal: 0 11/28/2018 08:49:12 PM Knob1_bytes: Hex: 0x0801 Decimal: 2049 11/28/2018 08:49:12 PM Knob2_bytes: Hex: 0x068f Decimal: 1679 11/28/2018 08:49:12 PM Knob3_bytes: Hex: 0x0ac5 Decimal: 2757 11/28/2018 08:49:12 PM Source_bytes: Hex: 0x0003 Decimal: 3 11/28/2018 08:49:12 PM -----------------------End----------------------- 11/28/2018 08:49:12 PM Entered action parser 11/28/2018 08:49:12 PM Knob values have changed 11/28/2018 08:49:12 PM Knob3 value has changed 11/28/2018 08:49:12 PM
